Terry NB Posted July 13, 2021 Author #76 Posted July 13, 2021 1 hour ago, Marcarl said: http://jbmindustries.com/Yamaha650.html Same size for 650cc and 1300cc?
Marcarl Posted July 13, 2021 #78 Posted July 13, 2021 2 hours ago, Terry NB said: Same size for 650cc and 1300cc? You'll have to check the site for size and type. They also have the slides I think. Just a suggestion, my experience is that they work well.
Patch Posted July 13, 2021 #79 Posted July 13, 2021 Given the age I don't doubt they may need replacing. However, if the slides don't need replacing and the needles are true? How can the cup be the cause? I don't remember reading vacuum leads in the thread. Take a picture and post it or x 4 Note from which carb they come from
Terry NB Posted July 13, 2021 Author #80 Posted July 13, 2021 2 hours ago, Patch said: Given the age I don't doubt they may need replacing. However, if the slides don't need replacing and the needles are true? How can the cup be the cause? I don't remember reading vacuum leads in the thread. Take a picture and post it or x 4 Note from which carb they come from Needs complete carburetor diaphragm assemblies (diaphragm and slides)
Patch Posted July 13, 2021 #81 Posted July 13, 2021 if that be the case it will need jets too. I consult the Diamond guy perhaps someone can post a link
Patch Posted July 14, 2021 #82 Posted July 14, 2021 I found the link, well worth discussing this over with Mike. @eusa1
Terry NB Posted August 10, 2021 Author #83 Posted August 10, 2021 Well the bike is in the shop. Has 4 new new diaphragms I purchased a used CDI from a person in the Forums and ends up it is not a fully functioning CDI. I will bring the original CDI to the bike shop for them to try. They state that it is the Grey Wire from the CDI/EMU that is the issue, as when they change cylinders, the trouble follows the wire.
