Guest snake_1962
I just ordered a 4 guage carb sync set. Now I need to know how to sync my carbs. I have an 05 RSTD with a little over 20,000 km on it. If anyone out there can send me a link or tell me step-by-step instructions, I would be very thankful. Dealer wants 3 hrs at almost $100/hr. Guages were only $95.
Snake:225:
Here you go and it's very simple. Your dealer is trying to rip you off. It's about a 15 minute job after you've done it the first time.
http://www.venturerider.org/forum/showthread.php?t=258
I also have this type gauge.
Question:
Do you reduce the diameter in the hoses to preform carb sync? On my Hayabusa you use a reducer in the line to the carbs. No mention in your article so I assume you just use the standard hose by it's self.
hh
Question:
hh
Your gauge should have come with reducers or restrictors. And yes you need to use them or the vaccum will be to great for the gauge.
That's what I thought. Thanks. :)
Sounds like a great project for tomorrow. :rolleyes:
hh
Guest 1154
hh
Did mine last week using themy newly aquired Carbtune. Followed the instructions from this site,worked great. :cool10:
Took longer to change the plugs.Now that job is a pain in the butt.
