So just bought my first venture .. very excited to say the least.. I chose this over a heritage soft tail.. So I'm wanting to change the speakers as well.as add a Bluetooth or even better a head unit were the cassete player is
.. does anyone have any experience with this ? Me and the wife are ready to.ride but she wants to listen to some tunes while doing so and the am/fm.radio.isnt doing it .
I'm with luvmy40 and go with patch cord in aux plug-in with radio( can take off front fairing and y connect to plug there so radio panel can stay shut  )I plan on doing this myself as I have a Sirius satellite radio I use.  When FM stations fade out or want commercial free I switch to satellite. Cheaper and less work.
I also recommend the aux cable.  Here is my setup, I play Pandora on my phone and have the choice of playing it on the speakers or piping it directly into our helmets through the OEM intercom system.
  • Thanks 1
I too went with a wire.
BUT, I added a "Y" connector under the front fairing that splits the Aux input into 2 sources. I then added XM radio and Garmin gps. The gps had an sd card slot. I loaded that with a couple of thousand oldies from my collection.
So now I have radio, tape deck, XM and the gps all available to listen to.
  • Thanks 1
I opted to use a Bluetooth 12v receiver. It’s inside the fairing and comes on with the key. It plugged into the aux plug  in there. I took out the tape deck and put charge ports there. I use iPhone so I’d need adapters to be able to charge and use aux plug at the same time. Several options out there.
  • Thanks 1
I did the same, except turned the cassette into a storage cubby & added a phone holder that is tied to 12v inside the fairing. It has a USB charging port that I plug right into the phone.  I stream either straight from tunes stored on the phone or Pandora over BT.
1 hour ago, daincrediblecolt said:
Rdawson can you show me pictures of what you mean putting charging ports in cassette slot
I don’t have pics with me but I gutted the cassette deck and used a parts store set that fit inside the deck case. It has a lighter plug and two USB ports. I kept the door operational so I can close it to look factory.
On 6/13/2021 at 9:00 PM, daincrediblecolt said:
Wiz .. where did u mount the amp too ?
I mounted the amp in the location of the original stereo amp inside the fairing.
