Frank from Loudon Posted June 7, 2021 Posted June 7, 2021 My 1991 Venture Royale makes a "howling" sound under light load. It goes away on deceleration and stronger acceleration. Does it in all gears. Sounds almost like the sound straight cut gears make. Steady sound, not warbling or oscillating. Any suggestions where to start looking? Roughly 50K miles. My other Ventures do not do this.
Squidley Posted June 7, 2021 Posted June 7, 2021 The gears in the Venture are strait cut gears. The bike has a very distinctive sound while it's running. I would wager that you're hearing normal sounds.
Midicat Posted June 8, 2021 Posted June 8, 2021 I have that sound at 3000 rpm. No matter what gear I am in.
BlueSky Posted June 9, 2021 Posted June 9, 2021 On 6/7/2021 at 6:37 PM, Frank from Loudon said: My 1991 Venture Royale makes a "howling" sound under light load. It goes away on deceleration and stronger acceleration. Does it in all gears. Sounds almost like the sound straight cut gears make. Steady sound, not warbling or oscillating. Any suggestions where to start looking? Roughly 50K miles. My other Ventures do not do this. That sounds like the Gen 2 gear whine everybody seems to think is caused by the clutch basket gear. My Gen 1 transmission (only 6k miles) is fairly quiet unlike my Gen 2. The Gen 2 has a loud whine/chirp at a certain rpm and almost all Gen 2s have that annoying whine/chirp.
Pro procrastinator Posted June 10, 2021 Posted June 10, 2021 Wait are yiu suggesting its a weight issue or a fear factor issue? Cause one of those if mentioned could be deadly
RDawson Posted June 11, 2021 Posted June 11, 2021 I keep telling everybody to install intercom mic/speakers in both rider and passenger helmets. The gear whine will no longer be the most irritating sounds you hear. 2
Marcarl Posted June 11, 2021 Posted June 11, 2021 1 hour ago, Pro procrastinator said: Wait are yiu suggesting its a weight issue or a fear factor issue? Cause one of those if mentioned could be deadly Just saying
saddlebum Posted June 11, 2021 Posted June 11, 2021 (edited) 14 hours ago, Pro procrastinator said: Wait are yiu suggesting its a weight issue or a fear factor issue? Cause one of those if mentioned could be deadly @Marcarlwon't be say'n anymore than he has on account of self preservation. You just gonna has ta read tween da lines. Edited June 11, 2021 by saddlebum 1
Marcarl Posted June 11, 2021 Posted June 11, 2021 44 minutes ago, saddlebum said: @Marcarlwon't be say anymore than he has on account of self preservation. You just gonna has ta read tween da lines. ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------================================================================================================================================= ____________________________________________________________________________________________________________________________________________________________----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
