Hi all,
when my scoot is on it’s center stand in first gear and clutch pulled in the rear wheel still spins,  I’ve never had a bike with a hydraulic clutch setup. The reservoir is half empty, what should my  Plan of attack be?
11 minutes ago, Shaw said:
Hi all,
Leave it, it's working just fine.
  • Like 1
  • Thanks 1
That works for me. Thank you!
Yes @Shaw as Marcarl say's leave it, that is just the hydro-static effect of the oil in the crankcase driving the gear and is perfectly normal. Its with the bike sitting on the ground and wanting to go forward on you even with the clutch pulled in when you want to start looking at things.
Edited by saddlebum
