Squidley Posted May 6, 2021 #1 Posted May 6, 2021 I've been searching a bit, trying to find a thread or post of anyone who has replaced their coil or coils with something aftermarket. I still think I have an intermittent coil issue. I wouldn't mind replacing coils, but looking for a more reasonable option than mamayama. Has anyone got some input if they've done something like this?
WIZ Posted May 7, 2021 #2 Posted May 7, 2021 I switched to coil over plug set up, here is a link to the discussion.
Squidley Posted May 7, 2021 Author #3 Posted May 7, 2021 5 hours ago, WIZ said: I switched to coil over plug set up, here is a link to the discussion. How are they holding up? I take it that the coil is all contained in each one of the caps without the use of a separate coil body?
Stasher1 Posted May 7, 2021 #4 Posted May 7, 2021 I've been wondering the same thing lately. I've had good luck with Dyna coils in the past, so that's the direction I'd be going if I knew they'd work. If they'll work properly, I can make them fit.
WIZ Posted May 8, 2021 #5 Posted May 8, 2021 13 hours ago, Squidley said: How are they holding up? I take it that the coil is all contained in each one of the caps without the use of a separate coil body? They are holding up well so far. Yes the coil is contained within the caps. 1
