Kinglicious Posted April 23, 2021 Posted April 23, 2021 Hello Everyone, I have a 2006 RSTD and am having fuel pump issues. Ordered a replacement from partzilla and it is constantly being back ordered. What are some good replacements. A RSV owner told me that the amazon pumps are the same as factory. I find that hard to believe. Thought it best to lean on the forum. Thank you in advance.
RDawson Posted April 23, 2021 Posted April 23, 2021 9 hours ago, Kinglicious said: Hello Everyone, I have a 2006 RSTD and am having fuel pump issues. Ordered a replacement from partzilla and it is constantly being back ordered. What are some good replacements. A RSV owner told me that the amazon pumps are the same as factory. I find that hard to believe. Thought it best to lean on the forum. Thank you in advance. The points are the most common issue for the pump. They are easily replaced and if my memory is correct they are around $30. Don’t use the cheap internet pumps, they don’t hold up.
Squidley Posted April 23, 2021 Posted April 23, 2021 If memory serves me correctly others have used this Mr. Gasket S42 pump. https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_fuel_pumps/carbureted_electric_fuel_pumps/parts/42S
Kinglicious Posted April 23, 2021 Author Posted April 23, 2021 I have changed the points and actuated the plunger to free up the diaphragm if it was stuck. Didnt work. I did buy a Mr Gasket pump but wanted to go with a stock repalcement.
vzuden Posted April 24, 2021 Posted April 24, 2021 14 hours ago, Squidley said: If memory serves me correctly others have used this Mr. Gasket S42 pump. https://www.holley.com/products/fuel_systems/fuel_pumps_regulators_and_filters/fuel_pumps/carbureted_fuel_pumps/carbureted_electric_fuel_pumps/parts/42S I have used the 42S and it works fine but you do need to do a little plumbing with common hardware store fittings. The most important thing to remember is you really need to turn off the fuel at the petcock when shutting off the bike since it doesnt have a shut off as part of the pump. It wasn’t a problem for me as I always shut it off whenever I park, even with the factory pump on my more recent bikes.
djh3 Posted April 24, 2021 Posted April 24, 2021 I did a write up here for the Mr Gasket pump swap. There is a check valve pump that is a Faucet I think is the name. But it aint cheap as it is FAA approved and available thru small aircraft parts suppliers. OK so I located one of these that is a little cheaper at Pegasus racing equip. You can take the part number and search for one for less. But this is the way to go. The conversion also allows you room to install a fuel filter where you can get to it. 1
Kinglicious Posted April 24, 2021 Author Posted April 24, 2021 Thank you. I need a link to your write up. I have a glass filter installed and have also purchased a Mr Gasket 42S pump. It has a fuel filter included. I just need instructions of the wiring and mounting of this.
tommarost Posted July 24, 2021 Posted July 24, 2021 I replaced mine in 2013 with this from Spruce aircraft, was around 45.00 at the time. No problems since. 05-40171 40171 FACET SOL ST FUEL PUMP 48.500 48.50
circa1968 Posted August 8, 2021 Posted August 8, 2021 I have a used OEM pump I keep on the bike as a spare. I got it from ebay for $30, I think it was from one of the cycle salvage places, came off a low-mileage bike and was super clean. Hit it with 12v & confirmed it works. It doesn't take up much space in the side bags & if my pump ever goes out on a long road trip, I can swap it in and then when I return, replace the points on the old one (sounds like that's the typical failure point) and then it becomes my ride-along spare. 1
circa1968 Posted August 9, 2021 Posted August 9, 2021 If you're still looking for one: https://www.ebay.com/itm/133798047178?fits=Model%3ARoyal+Star|Make%3AYamaha&epid=1423751850&hash=item1f26fc2dca%3Ag%3AnQoAAOSwkvpg1LEi&LH_ItemCondition=4
