guns_usn_20 Posted February 18, 2021 #1 Posted February 18, 2021 Hello; I have a question. Where do I install the 100 ohm resistor on my bike to keep the turn signals from flashing too fast? Thank You in Advance.
M61A1MECH Posted February 18, 2021 #2 Posted February 18, 2021 Here are two options; This link takes to you a product I make, you could use this harness that breaks into the wiring harness and put the resistors between the turn signal pigtails and ground. https://www.venturerider.org/forum/topic/62634-aux-lighting-harness-for-2nd-gen-venture/?do=getNewComment This link takes you to a post by Freebird that shows how to modify the OEM flasher to make it work with LEDs.
