Has any one used the bike master aux fue tank
I purchased one off amazon has hose at top and bottom. I hooked top to the vacuum that hooks under the tank and the bottom to the fuel line.
I noticed if i just open the petcock nd let the fuel flow i get fuel dumping ( not a whole lot) under the bike near the battery.
Is this Normal or do i need to bypass the fuel pump or what. i kept the bike running for a while use about 1/4 gallon by opening the petcock and closing it.
any help would be great.  Thanks
Pictures are the aux tank, and where the fuel is leaking
The upper line is a vent and does not need to be connected to anything.  I haven't used mine on my Venture but I think the bottom line should be connected to the suction side of the fuel pump.   I have used mine on my Kawasaki but it doesn't have a fuel pump.
