frankd Posted January 2, 2021 #1 Posted January 2, 2021 My 89 Royale has had a messy oil leak for longer than I'll admit, and I think I have at least one source fixed (the ignition sensing coil lead gromet). Yesterday it was 72 degrees here (central TN) and I decided that I'd work on cleaning up the greasy mess my engine had become. I had two spray cans of different engine degreasers, but really they didn't do a very good job. Yes, I did get quite a bit cleaned up, but there's still a lot left even though I brushed anyplace I could get to. I did some online research and there a lot of different cleaners that people claim work great, including Gunk foam (not what I used) and Purple Power. There were even some home brew concoctions that used kerosene and other things. What do you find that works for degreasing a motorcycle engine?
SpencerPJ Posted January 2, 2021 #2 Posted January 2, 2021 Purple power works for me, but really tough grease, CRC Brake Parts Cleaner is awesome. Keep it off your plastics.
saddlebum Posted January 2, 2021 #3 Posted January 2, 2021 (edited) We use purple power for de-greasing and cleaning diesel engines, drive-line, chassis's and wheel end parts such as brakes at work and so far with one exception it is the best product we have ever used. The one exception to it was one I used thirty years ago but cannot find any more and I don't even remember the name. I only know it was a blue concentrate. Edited January 3, 2021 by saddlebum
cimmer Posted January 3, 2021 #4 Posted January 3, 2021 I used Extreme Green Automotive Cleaner - Degreaser on my 89VR and it did a great job on the oil and grease on the front of the engine case for me. I believe I picked it up at an auto parts store or Menards. Rick F.
frankd Posted January 4, 2021 Author #5 Posted January 4, 2021 Taking into account that we live in middle TN. about 70 mi. SE of Nashville and a lot of things aren't available around here, I will try Purple Power next warm day. I've got a couple of gallons of Purple Power, and I 'was gonna' try that next anyway. Spencer, I will supplement the Purple Power with brake clean on the real nasty areas. Cimmer....Extreme Greem Automotive Cleaner-Degreaser looks real good also, but buying it is the problem. It shows ONLINE that you can buy it from Stearns (the manufacturer I think) or at Fleet and Farm stores. In Illinois and Wisconsin they have Farm and Fleet, but Fleet and Farm is a different chain. Our Grandson lives in St. Cloud MN., and there is a store there. The next time we get up to visit him again, I'll stop and pick up a jug there. Thanks
SpencerPJ Posted January 4, 2021 #6 Posted January 4, 2021 Whatever you do, don't get out a powerwasher, puts water in places it shouldn't be.
cimmer Posted January 5, 2021 #7 Posted January 5, 2021 I might have gotten mine at Fleet Farm now that I think about it. Rick F.
Pro procrastinator Posted January 5, 2021 #8 Posted January 5, 2021 Might be easier to put a harley emblem on it. Everyone expects them to leak. 1 1
RDawson Posted January 5, 2021 #9 Posted January 5, 2021 On 1/5/2021 at 11:09 PM, Pro procrastinator said: Might be easier to put a harley emblem on it. Everyone expects them to leak. Expand If you do that you have to trailer it everywhere. 1
Pro procrastinator Posted January 6, 2021 #10 Posted January 6, 2021 True but if you get your wife to drive the truck you could still ride the bike. Imagine being able to lay on the horn for ten miles or more and tailgating the whole way. Course she'll kill you when you get there.
N3FOL Posted January 21, 2021 #11 Posted January 21, 2021 (edited) I found this on the web and I usually trust Yamalube products for use on my bikes. Edited January 21, 2021 by N3FOL
luvmy40 Posted January 22, 2021 #12 Posted January 22, 2021 CRC also makes a non chlorinated brake cleaner that is an excelent degreaser and much less likely to damage plastics. I.e., it won't melt the plastic but it can discolor some so try it on a hidden bit first. I use this on my guns as well as brakes and engines. It's great for carbon build up. Be sure to recoat/oil anything that is prone to rust as it will strip any protective/lubricting coating off.
saddlebum Posted January 23, 2021 #13 Posted January 23, 2021 On 1/5/2021 at 11:28 PM, RDawson said: If you do that you have to trailer it everywhere. Expand Plus if it didn't leak to badly before it sure will after
Bob K. Posted March 15, 2021 #14 Posted March 15, 2021 On 1/2/2021 at 5:18 PM, frankd said: My 89 Royale has had a messy oil leak for longer than I'll admit, and I think I have at least one source fixed (the ignition sensing coil lead gromet). Yesterday it was 72 degrees here (central TN) and I decided that I'd work on cleaning up the greasy mess my engine had become. I had two spray cans of different engine degreasers, but really they didn't do a very good job. Yes, I did get quite a bit cleaned up, but there's still a lot left even though I brushed anyplace I could get to. I did some online research and there a lot of different cleaners that people claim work great, including Gunk foam (not what I used) and Purple Power. There were even some home brew concoctions that used kerosene and other things. What do you find that works for degreasing a motorcycle engine? Expand SuperTech Engine Degreaser from Walmart. It's cheap, so you can use lots of it, and it foams up to expand and fill cracks and crevices. Rise off with water and reapply as many times as is necessary to cut through thick crud. Did I mention it was cheap? So you can apply, rinse, and reapply multiple times without doing a lot of detailed scrubbing.
Beau-Kat Posted March 21, 2021 #15 Posted March 21, 2021 I have Purple Power in my shop for some needs. I use it on mower engines, but not anymore on my bike engines. I used it only once on my SR500 engine and it streaked the clear coat on the stator cover.
saddlebum Posted March 22, 2021 #16 Posted March 22, 2021 (edited) On 3/21/2021 at 9:04 PM, Beau-Kat said: I have Purple Power in my shop for some needs. I use it on mower engines, but not anymore on my bike engines. I used it only once on my SR500 engine and it streaked the clear coat on the stator cover. Expand Use Permatex gasket remover on the stater and other clear coated parts. It will remove the clear coat. No more clear coat streaking. Edited March 22, 2021 by saddlebum
Pasta Burner Posted April 24, 2021 #17 Posted April 24, 2021 (edited) On 3/15/2021 at 3:15 PM, Bob K. said: SuperTech Engine Degreaser from Walmart. It's cheap, so you can use lots of it, and it foams up to expand and fill cracks and crevices. Rise off with water and reapply as many times as is necessary to cut through thick crud. Did I mention it was cheap? So you can apply, rinse, and reapply multiple times without doing a lot of detailed scrubbing. Expand I didn’t know super tech had a degreaser. Mine isn’t too bad after I used the autozone brand earlier this week but it could use some more attention and foaming is an additional benefit. Edited April 24, 2021 by Pasta Burner
djh3 Posted April 24, 2021 #18 Posted April 24, 2021 I found similar results with the purple power. Over all it works good, but kind of streaky, same with simple green. But my son was messing around the other week and going to clean his wheels on his car. He had some of this new Dawn foaming dish soap and thought what the heck. He said it worked pretty decent.
