Guest Rafka Posted May 24, 2008 #1 Posted May 24, 2008 Guys, I have feedback in my speakers when my horn is activated. I found that if I turn my squelch up it goes away. Is this normal on a 02 Venture?? Any thoughts!!
bigbob Posted May 24, 2008 #2 Posted May 24, 2008 Guys, I have feedback in my speakers when my horn is activated. I found that if I turn my squelch up it goes away. Is this normal on a 02 Venture?? Any thoughts!! Mine was the same. Took them off & installed air horns, end of problems. Ride safe Bigbob
Abby Posted May 24, 2008 #3 Posted May 24, 2008 Mine does the same. This only happens when the CB is turned on. If i'm not mistaken I think this occurs with most RSV's. Abby
Jercoupe Posted May 24, 2008 #4 Posted May 24, 2008 Guys, I have feedback in my speakers when my horn is activated. I found that if I turn my squelch up it goes away. Is this normal on a 02 Venture?? Any thoughts!! Developed this problem when I installed my air horn. The forum here said it was probably a ground problem. I think it was because I disconected all of the conections in under the front faring and make sure it was tight. Noise went away for a while but did come back. I just didnt take the time to look for it again. Wondering if my new bike will do the same. Just finished the air horn today
V7Goose Posted May 25, 2008 #5 Posted May 25, 2008 This is pretty much standard on all RSVs - normal, a bit irritating, but nothing to worry about. Ride Safe, Goose
flb_78 Posted May 25, 2008 #6 Posted May 25, 2008 How often do you use the horn with the CB on to validate the need to find a repair for it?
spear Posted May 25, 2008 #7 Posted May 25, 2008 Damn. And I thought my horns were real loud. You mean I'm just getting feedback?
MAINEAC Posted May 25, 2008 #8 Posted May 25, 2008 Ah Spear you beat me to it... but I was gonna say it different... WTH That's a safety feature Yamaha developed.. in case you're riding around with the Radio too loud... It feedsback so you can hear the horn
MAINEAC Posted May 25, 2008 #9 Posted May 25, 2008 How often do you use the horn with the CB on to validate the need to find a repair for it? WHOA!! Flb is on a roll tonite
