I am replacing both lower throttle cables. On the pull side is a brass barrel about1 1/4" above the connecting barrel on the bottom of the cable. Can anyone tell me what it is for?
That would be a return stop so that the cables can only return so far and no further. It provides the stop you feel at the throttle grip when the grip returns to idle and so provides a home-base if you will.
