mttoews Posted August 1, 2020 #1 Posted August 1, 2020 i have an 85 VR. Some of the gauge backlights ie. Speedo and tach. Are not working. Are tbese replaceable? And with what?
SpencerPJ Posted August 2, 2020 #2 Posted August 2, 2020 I seem to recall that they are the simple wedge style bulbs you will find at the local auto store. Pull the headlight and take a look.
Patmac6075 Posted August 2, 2020 #3 Posted August 2, 2020 Pretty easy to open the gauge cluster...when I did mine, I replaced all the bulbs with LED’s. Just make sure you use the correct colors..ie, amber for turn signals, green for neutral and cruise, blue for High beams. I used red for the speedo and tach which I wouldn’t recommend (thought it would look cool). If I were to do it over I’d go with off-white or maybe green.
Prairiehammer Posted August 3, 2020 #4 Posted August 3, 2020 mttoews said: i have an 85 VR. Some of the gauge backlights ie. Speedo and tach. Are not working. Are tbese replaceable? And with what? Number 168 (wedge) 3.4 watts.
