EtRider Posted July 16, 2020 Share #1 Posted July 16, 2020 I have many new original parts that I will list here for anyone who needs them. I think they are for 1st gen but maybe 2nd gen also- I dont know, -they all were in a box I got along with the 84 Goldie that BongoBob had. Take a look and see if there is anything you need or want. Most are Yamaha Part # but a few are not. [TABLE] [TR] [TD=align: right]40171[/TD] [TD]FACET FUEL PUMP[/TD] [/TR] [TR] [TD]15 4474[/TD] [TD]PUMP SEAL KIT[/TD] [/TR] [TR] [TD]15-2542[/TD] [TD]CABLE[/TD] [/TR] [TR] [TD]1FK-12450-00[/TD] [TD]COOLANT PUMP IMPELLER SHAFT[/TD] [/TR] [TR] [TD]1J7-23415-00[/TD] [TD]STEERING BALL RACE COVER[/TD] [/TR] [TR] [TD]21-405[/TD] [TD]KL BEARING[/TD] [/TR] [TR] [TD]22-1004[/TD] [TD]STRNG STEM BRNG KIT(ALL BALLS BRAND)[/TD] [/TR] [TR] [TD]26H-11413-10[/TD] [TD]RACES[/TD] [/TR] [TR] [TD]26H-12459-00[/TD] [TD]GEAR[/TD] [/TR] [TR] [TD]26H-14412-00[/TD] [TD]COVER[/TD] [/TR] [TR] [TD]26H-14745-01[/TD] [TD][/TD] [/TR] [TR] [TD]26H-15338-00[/TD] [TD]ENGINE MOUNT DAMPER[/TD] [/TR] [TR] [TD]26H-15421-04[/TD] [TD]CRANKCASE COVER[/TD] [/TR] [TR] [TD]26H-15455-01[/TD] [TD]CRANKCASE COVER GASKET[/TD] [/TR] [TR] [TD]26H-163---00[/TD] [TD][/TD] [/TR] [TR] [TD]26H-16321-00[/TD] [TD]FRICTION DISK[/TD] [/TR] [TR] [TD]26H-16321-01[/TD] [TD]FRICTION PLATE[/TD] [/TR] [TR] [TD]26H-16385-00[/TD] [TD]CLUTCH BOSS RING[/TD] [/TR] [TR] [TD]26H-23153-00[/TD] [TD]SNAP RING[/TD] [/TR] [TR] [TD]26H-23188-00[/TD] [TD]ORING[/TD] [/TR] [TR] [TD]26H-24315-01[/TD] [TD]FUEL HOSE[/TD] [/TR] [TR] [TD]26H-26290-01[/TD] [TD]MIRROR-RH[/TD] [/TR] [TR] [TD]26H-26290-11[/TD] [TD]MIRROR-LH[/TD] [/TR] [TR] [TD]26H-26313-00[/TD] [TD]THROTTLE CABLE[/TD] [/TR] [TR] [TD]26H-83332-00[/TD] [TD]AMBER LENS[/TD] [/TR] [TR] [TD]26H-W0098-00[/TD] [TD]SEAL[/TD] [/TR] [TR] [TD]31A-W0047-00[/TD] [TD]CALIPER SEAL KIT[/TD] [/TR] [TR] [TD]31M-22906-00[/TD] [TD]AIRLINE HOSE[/TD] [/TR] [TR] [TD]3JB-14536-00[/TD] [TD]GASKET[/TD] [/TR] [TR] [TD]3JJ-14623-01[/TD] [TD]26H- COPPER BUSHING[/TD] [/TR] [TR] [TD]41R-82343-00[/TD] [TD]CABLE[/TD] [/TR] [TR] [TD]41V-00-3514[/TD] [TD]CABLE[/TD] [/TR] [TR] [TD]41V-26311-00[/TD] [TD]CABLE[/TD] [/TR] [TR] [TD]41V-85830-00[/TD] [TD]STATOR[/TD] [/TR] [TR] [TD]4NK-14451-00[/TD] [TD]GASKET[/TD] [/TR] [TR] [TD]4W1-W0041-00-00[/TD] [TD]CYL.KIT[/TD] [/TR] [TR] [TD]4XV-W0047-50[/TD] [TD]SEAL[/TD] [/TR] [TR] [TD]4XY-23121-10[/TD] [TD]SHOCK COVER[/TD] [/TR] [TR] [TD]4XY-81950-00[/TD] [TD]FLASHER[/TD] [/TR] [TR] [TD]501-50-06053[/TD] [TD]BARNETT CLUTCH SPRINGS[/TD] [/TR] [TR] [TD]59J-15113-00[/TD] [TD]15191--11455[/TD] [/TR] [TR] [TD]59J-28222-00[/TD] [TD]ACCESSORY PANEL[/TD] [/TR] [TR] [TD]90105-12374[/TD] [TD]LIGHT SHIELD[/TD] [/TR] [TR] [TD]90445-162A0[/TD] [TD]RADIATOR HOSE[/TD] [/TR] [TR] [TD]90560-17233[/TD] [TD]FRONT WHEEL SPACER[/TD] [/TR] [TR] [TD]92907-06600[/TD] [TD]ORINGS[/TD] [/TR] [TR] [TD]93102-28022[/TD] [TD]OILSEAL[/TD] [/TR] [TR] [TD]93105-45017[/TD] [TD]OIL SEAL[/TD] [/TR] [TR] [TD]93306-30317-00[/TD] [TD]BEARINGS[/TD] [/TR] [TR] [TD]ABA-26HCD-32-00[/TD] [TD]AIR WINGS[/TD] [/TR] [TR] [TD]FHO12AA[/TD] [TD]REGULATOR[/TD] [/TR] [TR] [TD]RU-2989[/TD] [TD]K/N FILTER SET[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [/TR] [/TABLE]YAMAHA.xlsx Link to comment Share on other sites More sharing options...
