ragtop69gs Posted July 14, 2020 Posted July 14, 2020 I am looking for a non functional radio remote control to use for parts, if you have one , let's talk. Thanks. Sent from my SM-N920V using Tapatalk
videoarizona Posted July 14, 2020 Posted July 14, 2020 What's wrong with yours, Jay? All the problems I've heard of stem from a dirty or loose connector inside the fairing at the radio junction. Mine freezes up and doesn't work until I take the connector apart and clean it good.
ragtop69gs Posted July 15, 2020 Author Posted July 15, 2020 What's wrong with yours, Jay? All the problems I've heard of stem from a dirty or loose connector inside the fairing at the radio junction. Mine freezes up and doesn't work until I take the connector apart and clean it good.It's pulled loose from the mounting plate and pieces of the plastic housing that secure the screw ferrels are gone. I think it was caused by brake fluid that splashed on it while bleeding the clutch several years ago. I'm trying to repair it again, but eventually I'm going to need a new housing or a complete remote. Sent from my SM-N920V using Tapatalk
videoarizona Posted July 15, 2020 Posted July 15, 2020 Yikes! Obviously not a connector problem! Good luck...
ragtop69gs Posted July 16, 2020 Author Posted July 16, 2020 Yikes! Obviously not a connector problem! Good luck... Thanks, I was able to patch it up again with some epoxy putty. Maybe Ill get by for a while.
djh3 Posted July 16, 2020 Posted July 16, 2020 Radio shack sells what they call project box you might be able to fabricate one up.
cowpuc Posted July 16, 2020 Posted July 16, 2020 Yikes! Obviously not a connector problem! Good luck... Thanks, I was able to patch it up again with some epoxy putty. Maybe Ill get by for a while. Raggy,, just noticed this,, is this what you are talking about? https://www.ebay.com/itm/00-Yamaha-XVZ-1300-XVZ1300-Royal-Star-Venture-intercom-radio-control-switch/312267727801?hash=item48b49b63b9:g:xZkAAOSwT0pbxdLb
luvmy40 Posted July 16, 2020 Posted July 16, 2020 Raggy,, just noticed this,, is this what you are talking about? https://www.ebay.com/itm/00-Yamaha-XVZ-1300-XVZ1300-Royal-Star-Venture-intercom-radio-control-switch/312267727801?hash=item48b49b63b9:g:xZkAAOSwT0pbxdLb No, that's the passenger volume and push to talk assembly. He's talking about the handle bar mounted "Head Unit". There is a new one for sale in the 2nd Gen Parts thread.
