saddlebum Posted July 14, 2020 Posted July 14, 2020 The 1st gen is such a high spirited animal you got to tie it down so it don't take off on you!!!
saddlebum Posted July 14, 2020 Author Posted July 14, 2020 Actually My reasoning for doing this is quite sane !!! the little guy next door has a form of autism referred to as Aspergers Syndrome. The other day I say him charger across our driveways and launch himself onto my motorbike. I literaly saw the kickstand loose contact with the ground. I feared the bike would topple over and severely injure the little guy. If you understand anything about Aspergers one of the characteristics is to literally shut out the rest of the world and function at times on impulse behavior. So driving a long stake into the ground and tethering the bike was my solution to avoid injury both to my bike and the little guy.
Flyinfool Posted July 14, 2020 Posted July 14, 2020 OK not what my guess was, I was guess to prevent the wind from knocking it over. Man if I had to child proof my whole property I would be in trouble.
zagger Posted July 14, 2020 Posted July 14, 2020 Hey, the 1st gen is pretty much the Vmax without the boost valves. I added the boost valves and it has plenty of gittyup. Just so ya know. zag
XV1100SE Posted July 15, 2020 Posted July 15, 2020 Ben....knowing you I need to remind you....don't trip over the strap or stake.
saddlebum Posted July 15, 2020 Author Posted July 15, 2020 (edited) Ben....knowing you I need to remind you....don't trip over the strap or stake.Don Knowing me I drove the stake flush into the ground with a flexible ring made from aircraft cable and why I swapped out the piece of rope I first used for the bright blue camlock binder Maybe I should make it bright orange OK not what my guess was, I was guess to prevent the wind from knocking it over Actually Jeff I had thought about doing this for years just for the reason you thought, but never got around to it. Seeing the little guy From next door just gave another more important reason to get-her-done. Also most of my yard is not child proof either but it is fenced in and I never had to worry about my own kids or now grandkids. But this little guy next door is a special case because of his state of mind due to the aspergers syndrome. Yesterday my son was checking his oil when the little guy shows up out of no where and throws a hand full of sand into the engine compartment. I feel sorry for his parents because he really is a hand full and having a nephew with the same affliction I can totally understand the struggles they are going through. Edited July 15, 2020 by saddlebum
XV1100SE Posted July 15, 2020 Posted July 15, 2020 Don Knowing me I drove the stake flush into the ground with a flexible ring made from aircraft cable and why I swapped out the piece of rope I first used for the bright blue camlock binder Maybe I should make it bright orange Sounds like you took precautions based on past experiences.
saddlebum Posted July 15, 2020 Author Posted July 15, 2020 (edited) Sounds like you took precautions based on past experiences.there is an old Dutch saying translted in english it says. " Even a jackass dosen't kick the same stone twice". Edited July 15, 2020 by saddlebum
Patmac6075 Posted July 16, 2020 Posted July 16, 2020 Glad to see you’re a conscientious neighbor! Cudo’s to you. I usually stand my bike up on the center stand when I don’t want a brisk breeze to knock it over.
saddlebum Posted July 16, 2020 Author Posted July 16, 2020 Glad to see you’re a conscientious neighbor! Cudo’s to you. I usually stand my bike up on the center stand when I don’t want a brisk breeze to knock it over.I used to but since tearing the cartilage in my knee I can no longer do that
