RandyT Posted June 27, 2020 Share #1 Posted June 27, 2020 Does anyone know where it is on the Star Venture? Link to comment Share on other sites More sharing options...
sldunker Posted June 27, 2020 Share #2 Posted June 27, 2020 I believe it is computer controlled. Your dealer should be able to change it with there Yamaha diagnostic tool. Link to comment Share on other sites More sharing options...
cowpuc Posted June 27, 2020 Share #3 Posted June 27, 2020 :sign yeah that: but even if it isnt and you are trying to get the idle to slow down for improved sound or what ever remember that the oil pump system is probably designed to pump at a certain pressure at factory idle spec.. Going below that factory spec can (at least in old school stuff,, this may not be the case in this modern stuff) lead to big issues.. Link to comment Share on other sites More sharing options...
RandyT Posted June 27, 2020 Author Share #4 Posted June 27, 2020 :sign yeah that: but even if it isnt and you are trying to get the idle to slow down for improved sound or what ever remember that the oil pump system is probably designed to pump at a certain pressure at factory idle spec.. Going below that factory spec can (at least in old school stuff,, this may not be the case in this modern stuff) lead to big issues.. Thanks for the good advice. It supposed to idle about 900-1000 rpm but mine is generally 1000-1100. I guess let the dealer figure it out. Link to comment Share on other sites More sharing options...
cowpuc Posted June 27, 2020 Share #5 Posted June 27, 2020 Thanks for the good advice. It supposed to idle about 900-1000 rpm but mine is generally 1000-1100. I guess let the dealer figure it out. Randy has it changed since new? Any alterations in the fuel/exhaust systems since new? If it has gone up since new and no alterations have been made I would be looking for a possible air/vacuum leak.. Even an improperly installed air filter can cause high idle in my limited experience.. I am with you brother,, I would not just ignore it but would definitely bring it up with the dealership and probably want to be informed of what they find when they fix it just in case I could know of something to keep an eye on if needed.. Your also welcome on advice my friend.. One thing I love about this place,, we talk motorcycles Link to comment Share on other sites More sharing options...
RandyT Posted June 28, 2020 Author Share #6 Posted June 28, 2020 Randy has it changed since new? Any alterations in the fuel/exhaust systems since new? If it has gone up since new and no alterations have been made I would be looking for a possible air/vacuum leak.. Even an improperly installed air filter can cause high idle in my limited experience.. I am with you brother,, I would not just ignore it but would definitely bring it up with the dealership and probably want to be informed of what they find when they fix it just in case I could know of something to keep an eye on if needed.. Your also welcome on advice my friend.. One thing I love about this place,, we talk motorcycles Thanks, the bike is new. A new 2018, just 1000 miles. I rode it a couple hundred miles today and the idle settled down to about 950. Link to comment Share on other sites More sharing options...
sldunker Posted June 28, 2020 Share #7 Posted June 28, 2020 Randy, mine acts the same way. It will idle a little high until the engine gets good and hot. Once it is good and hot it seems to idle in the proper range. I have over 17,000 miles on it. Link to comment Share on other sites More sharing options...
ZephyrChuck Posted June 29, 2020 Share #8 Posted June 29, 2020 My 2018, also acts like this. It has to get good and hot, then the idle settles down. It's just something you have to get used to. Link to comment Share on other sites More sharing options...
Du-Rron Posted June 29, 2020 Share #9 Posted June 29, 2020 Does anyone know where it is on the Star Venture? The idle is not adjustable. If you get no codes, nothing is wrong. The Service Manual is available on here. Link to comment Share on other sites More sharing options...
