DaNetFlunky Posted June 15, 2020 #1 Posted June 15, 2020 I can't seem to find how the throttle cables, brake and clutch lines route behind the windshield on an 05 tour deluxe. Anyone got any pics to share? Sure would help. Sent from my moto g(7) using Tapatalk
DaNetFlunky Posted June 17, 2020 Author #2 Posted June 17, 2020 Did i post this in the wrong place? Is this the stream where i can ask questions? Are you guys just ignoring me because I'm rich and famous? [emoji41] Sent from my moto g(7) using Tapatalk
Freebird Posted June 17, 2020 #3 Posted June 17, 2020 You posted it in the right place. Either it wasn't seen or nobody knows. Hard to believe that nobody knows so hopefully somebody will jump in here soon. Personally, I just don't know.
DaNetFlunky Posted June 17, 2020 Author #4 Posted June 17, 2020 Actually, I was hoping someone would take a picture of theirs and post it. Thanks for verifying the post was in the right place though. Sent from my moto g(7) using Tapatalk
cowpuc Posted June 17, 2020 #5 Posted June 17, 2020 I do not have an RSTD to snap some pics of for you DA but I did locate the Cable Routing section in the clubs RSTD shop manual.. If you go to page 13 in the manual here, this is where the fun begins.. Are you working from/do you own an actual shop manual for your bike? This one is, apparently, for the 96 to 01 models and it may or may not be stretching it to think it also applies directly to your bike.. Maybe check it out and see if it makes sense.. If not, maybe see if you could still pick up a shop manual as, even going all the way back to my 83's, the manuals have a fairly good definition of routing.. I do agree though,, nothing would be as good as having someone take some actual 's for you but maybe this will at least get you started in the right direction.. Puc https://www.venturerider.org/manuals/RSService.pdf
DaNetFlunky Posted June 18, 2020 Author #6 Posted June 18, 2020 Thanks Puc and Freebird. The manuals helped but in the end i just routed then in the most unbinding way i could get them behind the windshield crossmember support. The throttle cables still contact the windshield but so it goes. I could not get it to not contact. I'm riding the mofo as is! [emoji16] Let's ride! Sent from my moto g(7) using Tapatalk
