Is there any way to adjust the throttle tension? I don't know if it's gotten dirt in the cable or if something else is happening but it is getting worse. I've got a throttle rocker on it, but its getting so hard to turn it's not much help. Thanks.
Yes, there are throttle cable adjusters at both the throttle grip and the carbs. There is a junction box in the middle for the cruise control, so each side needs to be adjusted independently.
Have you thought of, lubing the cables???????? It will help flush out any dirt........:2cents:
I thought this was something you wanted to have and it was a problem if you did not have it!
Stop taking the medication! :crackup:
I knew that was coming. Thanks for all the other help. What is suggested for lubing the cables (I know, another loaded question) .
I use PJ1 Cable lube & a lubing tool as shown in attached PDF......
I have one of those THROTTLE BOSS throttle rockers on mine and on a couple occasions the rocker has slipped over and gotten hung up on the bar end weight. The friction of the rocker keeps the throttle from closing. Its just a thought but if you have one of those wrap around throttle rockers it could be the problem.
