Jerry,
Very Very nice job on it bud :happy34: I'm sure that will turn many heads as your rolling along. You ARE going to be riding it to Freebirds on Maintenance Day right?! :)
I am planning on being there,We are going to ride the Natchetz Trace Parkway in May.If everything goes well should be at Don's in June.
  DragonRider said:
Fantastic looking trike. How long did it take from start to finish.............Love the color. Congraulations
It is hard to say how long it took,you could build the trike in a week if you had everything you needed.I added a few things to the body I molded the license plate into the trunk lid,Installed Diamond plate to the inside of the trunk,increaced the depth of the trunk by cutting a 22'x8'' hole out and adding a box with lid now I have extra storage.I also molded aluminum to the side of the body where it bolts to the orig.frame to enclose it better.I made the bumper out of a custom truck grill and used what I had left for the luggage rack,worked out great.I also took a rear spoiler from a 87 buick and cut it down mounted it on the rear above the trunk.The color is the oem color for 05 RSTD.I think that is about all I did.Jerry M
That is one of the nicest trikes I have ever seen.
Now all you have to do is drop in that 360 hp hyabusa v8 on kneeslider.com or that W9 engine on hosepowersports.com.
182 cu in
262 lbs
526 hp stock...1005 turbocharged
Just kidding.....but that W9 would fit into my merc with lots of room left over.
  • 1 month later...
Guest HarveyWhite
great job!!! where did you get the kit? my son has a bike like this one and are woundering where you got the kit.
The kit is from Tri-Wing Ind.They are in Canada.The kit I used is the 2nd.gen.it uses the stock swing arm.They are a quality product.the body's are flawless.
Guest HarveyWhite
Thanks for the reply, ill look it up. Dose this one use the stock rear tire can't tell in the pics.
Guest Katydid
My heart is pounding!!! WOW. How much does it weigh finished? How do you back it up? I am gonna have to have one now that I've seen ures!!:sign I dont agree: :sign green with env :sign Rock On:
I would say about 1000 pounds,It rolls very easy and I don't have to balance it while trying to back it up.It is about 10 feet long and 56' wide so you need to be aware of the size when in a parking lot or going to the drive through at the bank or getting gas,you could loose a fender.
