Dbarbee Posted May 16, 2020 #1 Posted May 16, 2020 I’m looking for a front audio remote control housing. (The one mounted to the left handlebar) The base of mine was broken when I bought the motorcycle and was being held in place with a zip tie. I don’t need a working unit since my unit works, I just need the housing. Anyone have a non-working unit laying around? Yamaha part number 4XY-88168-00-00
Patch Posted May 16, 2020 #2 Posted May 16, 2020 You might consider bring it to a small machine shop for repair.
Dbarbee Posted May 17, 2020 Author #3 Posted May 17, 2020 You might consider bring it to a small machine shop for repair. I should’ve taken a picture when I had it off yesterday but the bottom of the plastic housing is completely broken out around the threaded insert that’s supposed to be there so I’m not sure what a machine shop could do. That does give an idea though if I can’t find a replacement housing. I might be able fill the hole in with epoxy and insert a new threaded insert into the epoxy. The other insert had pulled out of its hole on the bottom of the housing but a little super glue took care of that.
