Gogreengo30 Posted May 11, 2020 Posted May 11, 2020 (edited) I am stripping my bike to get it painted. I am working on getting the rear fender off right now. I cant figure out what is holding it on there. I removed the two bolts from the seat. In the manual it looks like there are screws underneath the side covers? Thanks in advance for any help on this! Edited May 11, 2020 by Gogreengo30 Figured out how to add pictures
Barnacle442 Posted May 11, 2020 Posted May 11, 2020 There are indeed bolts under those side covers, one on either side. you will need to remove the metal side covers and the plastics because of overlap. don't forget to disconnect your tail light.
Gogreengo30 Posted May 11, 2020 Author Posted May 11, 2020 There are indeed bolts under those side covers, one on either side. you will need to remove the metal side covers and the plastics because of overlap. don't forget to disconnect your tail light. Thanks for the help. I just wasnt quite sure because i was unscrewing those small flat heads but i felt like i was unscrewing for hours. Ill give it another shot tonight!
cowpuc Posted May 11, 2020 Posted May 11, 2020 I have found online parts fiches like this to be exceptionally helpful when my backs against the wall in situations like you describe.. Maybe this will help: https://www.yamahapartshouse.com/oemparts/a/yam/5004416ef8700209bc78e88d/fender
