...But I could only find 168's. The light bulbs.
Will 168's work in place of the 158's?
Also, if my dash is still dim, where can I look for possibly a bad ground wire or whatever?
Found this on the Internet "158=3.4w, 168=4.9w and 194=3.8w. These bulbs are interchangeable". Guess I coulda went with the 194.
I hope system can handle the extra 14.5 (?) extra watts. Wonder If I should take them back and get the 194's? What do y'all think?
Go with what you got. If it's too bright turn down the level with the control knob, and that might be your problem with it being too dim. If your going to make a change to save watts then go to LEDs from SuperBright.
