MY 86 Venture radiator fan was coming on at a hot temperature ( stock), which I think at 220 F was too high. I got the Napa part FS-147 and installed on the weekend. Now it comes on a lot earlier.. I like it.
Just a note if you do this .. the o ring that comes with the new thermo switch does not work.. It kept squishing out when i tightened. I carefully removed the o rink seal off the old, stock thermo switch and used it and no leaks.
Bike, while moving, keeps temp guage at just under 1/3.. prior to this change, stopped in traffic, gauge would climb to just over 2/3 before fan would come on.. Now it engages just over 1/2
FYI
ken
