Please not that until the new IP address of the server is finished propagating, clicking on some of the links will take you back to the older server. If you click a link and see http://www.venturerider.org...whatever in the address bar, then you have been taken back to the inactive server. Hopefully it won't take too long for it to complete the propagation.
OK folks....many of the items in the blue menu bars are hardcoded back to venturerider.org so if you click on them, they will take you to the old server. If you are navigating the forum, use the links on the left BETWEEN the two menu bars. They will keep you here where you should be.
Not for me, when i ping venturerider.org i still get the IP 64.somtheing pinged, not the 67.newServerIP
It takes some time, and i know how to work around it ...
not hitting the new server here either, still ping the old 64.xxx.xxx.xxx IP . Last server I moved took 2 days, to make the DNS changes, but we will get there sometime, so go for a ride after all your work for us here, and for your yard.
You gotta get a ride in there guy......
Brian
