mraf Posted May 18, 2008 #1 Posted May 18, 2008 Does anyone know if the torsion spring for the cruise control in the throttle cable box has any preload on it? {I.E. 1 or 2 wraps} Or does it just hook up easy? Took it apart and can see how it works but not sure of spring tension for assembly.
GeorgeS Posted May 18, 2008 #2 Posted May 18, 2008 I had mine apart twice, but don't remember putting Two turns on it. As I recall, I just put it in place. I just looked thru the Cruz control section of the Service Manual, does not seem to give any information. Good question !!
mraf Posted May 19, 2008 Author #3 Posted May 19, 2008 Thanks for the reply. All I did was put it in place. If yours worked after doing that it must be the right way to go together.
