I've searched the site and can't find any thread that talks about this.
Is there a trick to getting the rear valve cover out? I'm replacing the gaskets as they were cracked and leaking.
I can't seem to find a way to get the cover the clear everything and come out. I don't have the carbs off but from what I've read, it seems to me that people have removed it with the carbs installed.
Sent from my SM-G955W using Tapatalk
I literally just got the rear cover off 5 minutes ago. It's a very tight spot but if you handle it from both sides gently, it comes out. Getting back in is going to be tricky.
No, I don't have the carbs off. I've read here that it can be done without taking them off.
Fingers crossed, I'll get the cover back in and the gasket seated.
Yeah I didn't see them do it while the engine was in the bike, but I may have missed it.
I managed to get it out and back in.
Yes, getting the covers back in, with new gaskets attached is tricky. Two sets of hands helps. And, stick the gaskets on the cover grooves with a sticky gasket sealer before installing. Once the covers are in place, check and double check that the gaskets have seated properly.
