Flash105 Posted April 16, 2020 #1 Posted April 16, 2020 Getting ready to buy my second VRS I had a 2000 midnight, had to sell when we decided to adopt a child in 2004> 16 years later and I'm ready to start riding again. Looking for a second gen VRS!! What is everyone using to mount their I-Phone onto the handelbars?? Thanks for the help
Flash105 Posted April 16, 2020 Author #2 Posted April 16, 2020 What is the diameter size on the handle bars 2008 Venture
RDawson Posted April 16, 2020 #3 Posted April 16, 2020 I use a Ram mount that mounts on the brake handle clamp.
Leland Posted April 16, 2020 #4 Posted April 16, 2020 I use this to hold cell phone on my RSTD. https://www.cyclegear.com/accessories/mob-armor-mob-mount-claw
Heimdog Posted April 16, 2020 #6 Posted April 16, 2020 RAM Mount. 1,000s of miles and not a single issue.
stanG Posted April 16, 2020 #7 Posted April 16, 2020 Definitely the ram x mount. I've been using it for several years and no issues Sent from my motorola one using Tapatalk
Karaboo Posted April 17, 2020 #8 Posted April 17, 2020 Mine fits in my pocket with room to spare. Sent from my LM-V405 using Tapatalk
bpate4home Posted April 17, 2020 #9 Posted April 17, 2020 djh3 said: Ram Mount X mount. Ram x Mount for me too.
saddlebum Posted April 18, 2020 #10 Posted April 18, 2020 djh3 said: Ram Mount X mount. You can get kits with an assortment of motorcycle specific mounting options. https://www.rammount.com/shop-all/ram-x-grip/phone-mounts?facets I love mine even have one in the truck. Just make sure you order the right size for your phone Or tablet which ever you need. The smallest one is a tad too small the next one up should be about right for most of today's phones.
luvmy40 Posted July 13, 2020 #11 Posted July 13, 2020 As usual, I have to be the odd man out! I just mounted this: https://smile.amazon.com/gp/product/B088FNVGWP/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 on my '06. It seems rock solid and has excellent reviews. Wireless quick charge and USB port also with quick charge. The mount is versatile enough to make it possible to locate the phone pretty much anywhere you want to. Unless it falls apart on the ride to Niagara, I can't see a better option for $40.00 delivered.
haup9 Posted July 18, 2020 #12 Posted July 18, 2020 luvmy40 said: As usual, I have to be the odd man out! I just mounted this: https://smile.amazon.com/gp/product/B088FNVGWP/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 on my '06. It seems rock solid and has excellent reviews. Wireless quick charge and USB port also with quick charge. The mount is versatile enough to make it possible to locate the phone pretty much anywhere you want to. Unless it falls apart on the ride to Niagara, I can't see a better option for $40.00 delivered. Thanks for this suggestion. I just ordered it.
Freebird Posted July 19, 2020 #13 Posted July 19, 2020 I just ordered that one also. Hope it works as stated. We'll see.
luvmy40 Posted July 20, 2020 #14 Posted July 20, 2020 Well, I didn't make the Niagara run but we did ride down to Hocking Hills/Logan, OH for a Blacksmithing class and the phone mount was solid. Rock steady, no vibration and the wireless charging work perfectly with my S10+. I didn't hard wire mine to the battery, I wired in a power port connector(cigarette lighter adapter) and plugged it into the power port in the left inner fairing. That way there is no chance that I forget to turn it off and kill the battery.
Freebird Posted July 25, 2020 #15 Posted July 25, 2020 Received mine earlier this week. Mounted it and ran the wires into the fairing and also tied into the power port on the Ultra Classic. Haven't ridden yet but test it and it charges with eh USB as well as the wireless charger. My one little complaint so far is that the mounts is a bit loose where the ball is molded into he back of the mount. It is a bit sloppy. It would probably not matter on the Venture but will likely shake around a bit on the Harley. I may end up putting some epoxy on the back but will wait and see if it seems to need it.
M61A1MECH Posted July 25, 2020 #16 Posted July 25, 2020 luvmy40 said: Well, I didn't make the Niagara run but we did ride down to Hocking Hills/Logan, OH for a Blacksmithing class and the phone mount was solid. Rock steady, no vibration and the wireless charging work perfectly with my S10+. I didn't hard wire mine to the battery, I wired in a power port connector(cigarette lighter adapter) and plugged it into the power port in the left inner fairing. That way there is no chance that I forget to turn it off and kill the battery. If you want to wire to the back side of that power port inside the fairing, I can set you up with neat little plug and play 2 pin break out adapter.
