Has anyone had to replace this o ring? I rebuilt my front master cylinder and in the process I pulled the sensor out and noticed the only reason fluid does not leak out the bottom of the reservoir is the o ring around the shaft on this sensor. The rebuild kit did not include this o ring. I have it back together and it feels like it works just fine but I have a leak. Not sure where it is but the bottom line is there is a leak. It would be easy enough to replace the o ring. I am wondering if it is a specific size that is easy enough to come by. I checked and it does not appear to be available from Yamaha. Considering it is 32 years old it seems like it would not hurt to replace it
