Guest cwil2988
What is the diameter of the headpipe where the muffler fits over? thought someone might readily know this without me having to tear mine completely apart to measure it.
found some aftermarket mufflers I am thinking about trying out.
Thanks
Craig
:stirthepot:
Just swapped out my 06 rsv pipes, if they are the same as rstd? then the ID of the slipons is 1.75 in. I put Harley slash cuts on, they fit great with Squidlys adaptors. Craig
Guest cwil2988
They are the same, thanks so much for the info- exactly what I needed
Craig:322:
the only thing you may need to watchout for is the fins hitting the saddlebags, where the fins comes up off the main body of the mufflers. i put samson fishtails on my 01 standard, with venture hard bags and they hit, so i put 4 thick washers and a longer mounting bolt to move them down to miss. i would make sure they (company) has a good return policy.
