Has anyone done instructions on changing the rear tire. The sevice manual seems like a lot of work. My RSTD was pretty easy but I havn't done this one yet.
Search you tube. There is a video of it out there.
I have done mine twice now. The first time wasn't real fun as there is a learning curve. The second time went well.
Two things come to mind. Check alignment marks on each side. This is your starting point when you start to tighten belt back up.
The second thing is when reinstalling tire, make sure that axle is inserted and lined up with opposite side before you install caliber. Good Luck
