Whats the best advise for getting the mufflers off the bike? They are suppose to be slip on mufflers, but they ain’t coming apart
They can be tough to remove after being on for several years. You just have to keep at it. Move them up and down and then side to side and they will eventually loosen up enough to pull off.
Spray some PB Blaster or any other penetrating oil you have around, in the joint, let set over nite, Tap end of muffler with block of wood and hammer next day. Spray some more then work up and down, side to side and twist.
Always worked for me. Bike will smoke and stink for awhile after you replace pipe and start it, but it clears once oil is burnt off.
Good Luck, Craig
I got them off finally and got the others on. ImIt took some work but I got it. I think I’m going to like the new sound. Here is a pic of one installed
Sent from my iPhone using Tapatalk
