I have read that everyone says to put on a set of Progressive springs on the front. I am going to have my forks rebuilt and I wanted to know if this is the time to install them? They go inside of the fork tubes right? Does anyone know where I can get a set and what the part number is? Can I still use the air suspension?
Thanks,
Kevin
I believe I ordered mine direct from Progressive, but there are several aftermarkets. I'm not running any air in the front forks after I installed the new springs, and yes, this would be the ideal time to install them.
P.S. I love the new ride and handling.
Thanks,
Kevin
The progessive part is #11-1112, yes you can still run air if needed / wanted.
I just put new Progressives in both the front forks and on the rear shock. i already had Progressives in the front and thought they had went bad but actually it was the rear spring giving such a rough ride. Made all the difference in the world. I got them from Rick Hafferkamp at: http://www.buckeyeperformance.com/
Dick :):):)
