DesertLawman Posted March 27, 2020 #1 Posted March 27, 2020 I bought a Sena Freewire to use with the 7 pin onboard communication system on the Venture TC. I tested it out before the upgrade and everything was working fine. However, after the upgrade, I no longer have any sounds coming out in my headset. I can use voice commands and the system recognizes the voice input, but the radio, CB, XM and all other media no longer can be heard in my helmet. I made sure all the helmet boxes for both rider and passenger are checked in the audio settings. Im not sure if this is a bug in the new version that has not been found yet. I wish I was able to obtain the original stock version of the system so I can revert and use the system as it was before the upgrade. Has anyone else had this situation?
bpate4home Posted March 27, 2020 #2 Posted March 27, 2020 Did you look under the settings / audio output that your default is all checked? It will then auto switch when a headset is plugged in.
