Gambler Posted May 15, 2008 Posted May 15, 2008 The CB antena wire goes into the black box under the trunk where do U connect the meter to adjust the SWR Gambler:15_8_211[1]:
gibvel Posted May 15, 2008 Posted May 15, 2008 (edited) Have to pop the trunk up (I usually just undo the screws, tilt it forward and prop up with the appropriate length piece of wood), open that black box and connect to the connectors in that black box. You have to have the special connectors like this: http://www.sierra-mc.com/proddetail.asp?prod=SIE%2DSWR12 You may want to check the audio and CB connectors under the passenger seat when you're finished. I know that the extra tension, from tilting the trunk up, sometimes disconnects my passenger audio plug under there. Edited May 15, 2008 by gibvel
Gambler Posted May 17, 2008 Author Posted May 17, 2008 Thanks Gibvel, thats what I was looking for & thanks for the link Gambler:banana:
BOO Posted May 18, 2008 Posted May 18, 2008 It can be checked any place between the radio and the antenna. Best is right at the radio but easiest is under the seat I'm thinking. Jerry
Marcarl Posted May 18, 2008 Posted May 18, 2008 Hey don't worry about, I checked mine and the meter worked just fine, so we know the meter is good to go.
Al Bates Posted May 18, 2008 Posted May 18, 2008 Thanks Gibvel, thats what I was looking for & thanks for the link Gambler:banana: Thanks Gambler I ordered a set. I been looking for them. I have the meter but no cables. Now I have to fine out the correct way how to use the meter.
Marcarl Posted May 18, 2008 Posted May 18, 2008 Thanks Gambler I ordered a set. I been looking for them. I have the meter but no cables. Now I have to fine out the correct way how to use the meter. Hook in the cables, follow the direction, the one marked (on the meter) to the transmitter, to the radio, the one marked to the attenna to the attenna. Move to an outside location, so not in your garage, although that will work, it isn't the best, juice up the CB, set the meter to FWD and squeeze the PTT switch, Now set the meter to 'set' with the adjustment wheel. Release the PTT, switch the meter to REF and again squeeze the PTT. The meter should read less than 1.5. If so, you're done, you have a good match. If it's more than 1.5 you can try adjusting the attenna to get it lower, the lower the better. Often we have to be happy with what we have because of the bikes we ride, very little ground plane makes for a hard to match system.
Al Bates Posted May 19, 2008 Posted May 19, 2008 Hook in the cables, follow the direction, the one marked (on the meter) to the transmitter, to the radio, the one marked to the attenna to the attenna. Move to an outside location, so not in your garage, although that will work, it isn't the best, juice up the CB, set the meter to FWD and squeeze the PTT switch, Now set the meter to 'set' with the adjustment wheel. Release the PTT, switch the meter to REF and again squeeze the PTT. The meter should read less than 1.5. If so, you're done, you have a good match. If it's more than 1.5 you can try adjusting the attenna to get it lower, the lower the better. Often we have to be happy with what we have because of the bikes we ride, very little ground plane makes for a hard to match system. Thanks Carl.
