Guest sjhrace
i bought a harbor freight trailer to pull behind the bike
i wired the thing like it said but im having problems.
when i turn on the key the running lights come on and everything looks fine
but when i hit the break the right light goes out and the left light gets bright
when i turn on the right or left blinker both tail lights blink
this is really pissing me off its only 4 damn wires how could it be this hard?
please help as i really need it
Ace
I think you need an adapter. The RSV does not have the same circuits for tail/run/turn as a car. To function properly it would need a 5 connector lead.
Guest tx2sturgis
You have something wired wrong, but you knew that right?
Buy one of those little trailer lite testers...to make sure you have the bike connector wired right, then you will know if the problem is in the trailer or the bike. They dont cost but just a few bucks. You can get these at boat/rv supply places or the internet:
http://www.etrailer.com/pc-T~30512.htm
Did you install a modulite, or anything else to interface the bike wiring to the trailer? or did you just splice into the bike wiring directly? Motorcycle wiring is a 5 wire system, and to run a 4 wire trailer you need an adapter or module to make the conversion.
We just need a few more facts to help with this.
If you are only using 4 wires to a 4 pin connector you need an adapter. The scoot has separate signals from the brakes. More like a european setup.
The Modulite is the adapter.
When i wired mine I bought a adapter from auto parts house to convert 5 light to 4 light, it isused for foriegn made vechiles. I wired to the tail light and I have had no issues!
BikerJohn
walmart has a hopie coverter to wire the 5 to 4 wire system so they work right.on the trailer the brake and turn signals operate the same bulbs but on the bike the turn sigs and brakes are seperated.
Ace
I have the modulite controller and mine has the same issues. I have double and triple checked the wiring and it is right. I must have gotten a bad unit. I am going to try to return it and try the hoppie instead.
I just bought 2 small amber lights and mounted them and wired my signal lights to them and the tail and brake to the existing lights. It will work good then. You don't have to buy the adapter.
Guest tx2sturgis
Before you do, let me ask you this: Have you changed any of the turn or brake lights to LED's? If so, that can cause some weird results with a modulite. I know how to fix that, if you have done the LED thing.
