THE LAST TIME YOU CHECKED YOUR AIR FILTER WAS THERE OIL IN YOUR AIR BOX?
ARE YOU TIRED OF TRYING TO GET THE AIR BOX VENT TUBE BACK ON THE CRANKCASE VENT WHEN YOU REMOVE THE AIR BOX?
WELL, HERE'S THE ANSWER! THE CRANKCASE VENT FILTER UPGRADE!
REMOVE ALL OF THAT PLUMBING THAT CLUTTERS UP THE UNDERSIDE OF YOUR AIR BOX,
STOP COLLECTING OIL IN THE AIR BOX AND GIVE YOUR ENGINE A SHOT OF "CLEAN AIR" INSTEAD OF AIR FULL OF OIL MIST. THIS
HIGH QUALITY, WASHABLE, REUSABLE CRANKCASE VENT FILTER COMES WITH VACUUM PLUGS TO SEAL OFF THE STOCK AIR BOX
AND COMES WITH ITS OWN MOUNTING CLAMP. THE PRICE IS $40.00 WITH FREE USA SHIPPING. THE INSTALL TAKES LESS THAN 30
MINUTES AND CAN BE DONE WITHOUT REMOVING THE AIR BOX. FULL WRITTEN INSTRUCTIONS ARE INCLUDED. YOU CAN CONTACT
ME AT: skydoc17@gmail.com IF YOU HAVE ANY QUESTIONS! THANKS FOR VIEWING MY AD!
Edited by skydoc_17
ADDED PICS!
  • 7 months later...
Do you know if this will work on 2nd gens? I have an 05 RSV and the hose between the crankcase vent and the airbox is cracked/dry rotted. I think the connection is different on the 2nd gen though, cause mine connects under the tank after the airfilters where the left and right side come together.
Thanks!
