Sunman Posted May 12, 2008 Posted May 12, 2008 I am looking for a hand air-pump for the suspension on my '06 RSTD. I found one that had a pressure gauge attached, but it was a 150 PSI gauge, and the range that I would need, was so small I could not get an accurate reading. Can anyone suggest a good air pump for our bikes, and a company that has a decent price on them? What PSI range should I look for ? I figured 50 PSI max reading would be fine, since the front is so low, and the rear is 40 max I believe. And in another thread someone mentioned a pump with a 'Zero loss' chuck. I have had no luck sourcing that out on the net. Any help most appreciated. Also, what kind of pressure should I be running in my rear and front shocks? Here are the stats, I am 250 lbs, mostly ride by myself, but on occasion I have a 125 lb passenger. Any suggestions? Sonny
Cougar Posted May 12, 2008 Posted May 12, 2008 http://www.whitehorsepress.com/product_info.php?products_id=5619 I Love mine.. Jeff
jrcain32 Posted May 12, 2008 Posted May 12, 2008 Check your local Harley-Davidson dealer. They have the Progressive pump with the "Harley" logo on it. I believe they have two different ones, 0-30 and 0-60. Get the 0-60 one. Believe it or not, it's cheaper at the Harley shop than it is from Progressive. I think I paid $40.00 for mine...
Bubber Posted May 12, 2008 Posted May 12, 2008 (edited) I have the Progressive 0-30 PSI and I got it from Dennis Kirk 10 mile s up the road. NO shipping. About $40.00 or so. I also bought the kit that links both fork legs together so it balances the preasure. ~$20.00 7 PSI max front Hope that helps Steve Edited May 13, 2008 by Bubber
halfwitt Posted May 12, 2008 Posted May 12, 2008 I like the Dennis Kirk guage. But be careful with the item number you order. I accidently ordered the 0-100 psi which doesn't do you a whole lot of good: Five models of gauge-mounted pumps are ideal for low-volume, high-pressure systems (i.e. forks, shocks) Each Micro Pocket Pump has a 2 3/4 in. stroke and a 9 in. flex connector, with a built-in gauge and bleed valve Lightweight and easy to use; each stroke adds .7 cu. in. of air A special connector prevents air loss when connecting and disconnecting Available in: 0-15 psi: 28236 0-30 psi: 28234 0-60 psi: 28235 0-100 psi: 28224 0-300 psi: 282090
lateralvibe Posted May 13, 2008 Posted May 13, 2008 SUNMAN, I have a Progressive pump 0-60 lb for sale $25.00 and you pay shipping. I sold my Venture a while back and do not need the pump. Still in the box and used very little. Just offering.
Sunman Posted May 13, 2008 Author Posted May 13, 2008 SUNMAN, I have a Progressive pump 0-60 lb for sale $25.00 and you pay shipping. I sold my Venture a while back and do not need the pump. Still in the box and used very little. Just offering. I will take it. PM on the way.
Sunman Posted May 15, 2008 Author Posted May 15, 2008 SUNMAN, I have a Progressive pump 0-60 lb for sale $25.00 and you pay shipping. I sold my Venture a while back and do not need the pump. Still in the box and used very little. Just offering. Lateralvibe, I have responded to all of your emails, and sent you a PM as well. I am not sure why you are not getting them. I do want the pump, and I just need to know how much shipping is to Hamilton, Ontario Canada. My postal code is L8W 2Z5. Thanks for your time. Sonny
lateralvibe Posted May 15, 2008 Posted May 15, 2008 Sonny, I do not know what the deal is with the PM or the e-mail on my end, I'm getting neither. Thanks for following up. I'll get a quote for shipping and get back to you. Thanks, again Lateralvibe
Sunman Posted June 3, 2008 Author Posted June 3, 2008 Just got my suspension pump today, thanks Lateralvibe!! It seems to work fantastic, I only put about 12 psi in the rear shock, just to see how I like it. Thanks for helping me out. 3 cheers for lateralvibe!
lateralvibe Posted June 9, 2008 Posted June 9, 2008 Sunman, A pleasure doing business with you, I'm glad the pump is woring out for you and fills your needs. Hope to actually get to meet you one of these days. Paul
