Ken Parker Posted May 12, 2008 #1 Posted May 12, 2008 I guess it is official, my children are right, I should not be allowed near electronics. I have a just purchased a 05 RSV and have read the owners manuel (on Yamaha Motors site) and I can not get set my favorites on the radio. Can anyone give me any advise? Thanks
Twenty7Delta Posted May 12, 2008 #2 Posted May 12, 2008 push audio until FM or AM is selected, then you can do it a couple of ways. 1. if you hold the UP (or down) button for more than one second the frequency will start to change until it finds a station. Once on that station you can hold the SELECT button for more than one second and then the number to the left of the frequency display will flash and then you can use the up and down buttons again to choose the memory you are saving to (1 through 6 for each FM group). Then you push select again to lock it in. 2. push and hold the SELECT button for about 1 second and then when the numbers on the left of the display start flashing push the down button until there is an "A" in that spot. The cycle is 1...2...3...4...5...6...A if you use the UP button. After you do that the radio will scan through the band and save every station it finds into each of the 6 memories until it has filled them. I hope that makes sense - it's harder to write out than demonstrate.... Maybe I should make a video. My dealer tried to show me when I bought the bike but he had it all wrong and the manual isn't very well written... Good luck, let me know how it goes...
Twenty7Delta Posted May 12, 2008 #4 Posted May 12, 2008 awesome, glad it worked because I went and tried it and should have put that you need to hold the select button for more than 2 seconds... Glad you figured it out, have fun!
KiteSquid Posted May 12, 2008 #5 Posted May 12, 2008 Rant mode ON: I HATE the way Clarion made this work!!!! I sure wish that Yamaha Motor Company used a radio from Yamaha Electronics Company instead of this POS that came from the lowest bidder!!!!!!!! Rant mode OFF:
