Went with guy from work to the Rock's Harley test ride yesturday. Don't know why people say once you ride a Harley you won't ride anything else. Was not impressed enough to buy one unless I had amnesia and won the lottery. Was gad to get back on my own bike without all the VIBRATION and hand numbing ride.
Guest BluesLover
Hey Phil - which bike did you take out?
I took out the Heritage Softail Classic. It wasn't too bad, but I couldn't get used to
1) the right turn signal being on the right side (kept hitting the horn :bang head:);
2) the heel and toe shifter ... kept on hitting the back of my heel against the shifter.
I also didn't like having to look down at the tank to find my gauges and stuff.
Oh well ... I had really wanted to try out the Rocker (to see if it compared to the Yamaha Raider), but never even took it out. As soon as I sat on it, with my short legs, my left calf was sitting up against the primary, so I didn't think it was worth having a "hot leg" all day long.
Cheers,
I took out
1-Ultra Classic Electra glide(full dressed-one up from Electra glide Classic)
Found fairing was too close compared to mine
separate turn signals were a pain
heel toe shifter was too high to use and didn't look adjustable
mirrors on handle-bars were a pain too try and look out of(too close to hands and cose to elbows
no gear indicator besides Neutral
not as much protection for legs:thumbdown:
2-Fat-boy
not used to not having fairing
good power-band
heel-toe shifter not fitting to be used:thumbdown:
3-Road-king
TOO much vibration at idle but not bad ridding
windshield too close
heel toe same as other's
no gear indicator :thumbdown:
Main opinion is not a likely buy in near future
Got back on after rides and didn't even know if it was running-----noooooo vibration and just enuff wind protection for my taste
Even tho mine has lots of fairing out front and top heaviness it is the only bike I would have for now:173::173::173::173::173::173:
