Has anyone experience issues with ABS and/or traction control?
For the past couple of weeks every time I ride the ABS light eventually comes on. Inconsistent on how far or how fast I have to ride before it comes on, but for sure by 10 minutes into the ride it pops on and remains so until the bike is turned off and then on again.
Going to drop it off at the dealer to check it out in the near future, just hate being without it even for just a few days.
I did have the rear tire replaced shortly before this started happening.
Sent from my SM-G975U1 using Tapatalk
There is a sensor on the rear tire for the abs. Perhaps the screw that holds it in place is not tight. The sensor is located in the caliper bracket. easy to check.
That would be the place to start, ther rear. Look at the tone ring try to see if any of the "teeth" are bent or something stuck in them. Then check the pick up which might be had depending on how bad its hidden.
