Red Ryder Posted September 27, 2019 #1 Posted September 27, 2019 Hey all, I noticed when hitting bumps or at certain speeds, the front will shake on the RSV-Hannigan Trike. Does anyone have a Front Stableizer on there RSV Trike? If so where to buy? Thank You, Later-
cecdoo Posted September 27, 2019 #2 Posted September 27, 2019 Will shake at slow speeds, its the nature of the beast. I havent seen a hannigan rsv with a stabilizer. I know when I rode Jonseys Hannigan Wing it did the same thing. If you find a solution I would really like to hear about it. Craig
Red Ryder Posted September 28, 2019 Author #3 Posted September 28, 2019 Thank You Craig! Yesturday road a friends 2019 Harley Tri-glide, had very little if any shaking over bumps or various speeds. Would be great to eliminate the shake on the RSV, have to do a bit of ingenuity, but maybe. Later-
bikenut Posted October 4, 2019 #4 Posted October 4, 2019 Check your steering head bearings . If they are set loose the front end will shack. You can set them on the tighter side because it is 3 wheels and does not lean any.ore. my 86 tri-wing kit did the same thing and i tightened up the steering head bearing and help very much. Give it a try. Good luck
Red Ryder Posted October 7, 2019 Author #5 Posted October 7, 2019 Check your steering head bearings . If they are set loose the front end will shack. You can set them on the tighter side because it is 3 wheels and does not lean any.ore. my 86 tri-wing kit did the same thing and i tightened up the steering head bearing and help very much. Give it a try. Good luck Thank You Keith, I will check and tighten the front end. Later-
