So I have been having this plastic rattle just off idle for quite some time. Last night it finally got pretty loud. I messed around with it today and isolated it to the upper wind wind on the right side. It was the top fitting. I remove the entire wind wing. Future warning- the lower mount for the wind wing is a bugger. There are two screws that hold it to a bracket that is in the inside of the fairing. The bracket is just hanging inside of the fairing so when you take the screws out it falls down into a place that it is a ***** to find. So if your wind wing is rattling just take a small screwdriver and pop the upper pin out. Find a oring that fits the pin and reassemble. Takes care of the rattle.
After driving the bike for a few days the fuel door cover started rattling a little bit. This is the piece that I always thought would rattle. Easy fix. Took a small piece of foam and it just sits in groove in front of gas cap. All is well.
Edited by sldunker
