BlueSky Posted August 12, 2019 #1 Posted August 12, 2019 As the title says, my left saddlebag won't open. The button pushes down and springs back up but nothing happens and it doesn't take as much effort to push it down as the other bag. I've read some of the posts on the forum and tried some of the methods. I'm sure I'm going to have to either drive the hinge pin out (Is that possible?), cut it with a dremel, or drill the hinge pin out. What method do you guys recommend? Thanks!
BlueSky Posted August 12, 2019 Author #3 Posted August 12, 2019 Good One! As i stated, "The button pushes down and springs back up but nothing happens". Knowing what you know about these bags, you know that the button can't be pressed down if it is locked.
RDawson Posted August 12, 2019 #4 Posted August 12, 2019 Good One! As i stated, "The button pushes down and springs back up but nothing happens". Knowing what you know about these bags, you know that the button can't be pressed down if it is locked. It can on a 2nd gen.
BlueSky Posted August 12, 2019 Author #5 Posted August 12, 2019 It can on a 2nd gen. :banana: OMG! You are correct, Sir! It was locked and I thought the unlocked position was the locked position because it was much harder to push than the other side. Oh well, senility is setting in. Perhaps I should get a 3 wheeled pedal trike? I suppose a little lube is in order to make sure the locks work well on all the luggage. Thanks for helping a senile old fart!
RDawson Posted August 13, 2019 #6 Posted August 13, 2019 I just posted trying to get a laugh. Glad it worked out.
XV1100SE Posted August 13, 2019 #7 Posted August 13, 2019 Good thing you didn't suggest the other way to open the lid of a saddlebag....which is to drill. Always start with the simple things. Why do you think when you call support they ask "is it plugged in?", "have you rebooted?". Always the simple to start.
