labill Posted August 1, 2019 #1 Posted August 1, 2019 I posted before about my clutch leaking at the leaver. As recommended I cleaned out the reservoir and replaced the parts. However, still have a leak, not near as bad but enough that after a ride I have to refill. Let set and when I rubbed my finger under the leaver at the connection I get fluid. Thinking I may need to replace the reservoir? Thanks again, labill
Rafterd Posted August 1, 2019 #2 Posted August 1, 2019 If you’ve rebuilt the master cylinder, and confident you did it right, then yes that’s about all that left. Not sure why. Ive rebuilt hundreds of them. Never saw one go bad. But that doesn’t mean this is a first.
labill Posted August 1, 2019 Author #3 Posted August 1, 2019 I am sure I did. I put the new parts back in the way the old ones came out. The diagram in the large repair book does not help. If there is a better picture of one together could point me in the right direction. No harm in double checking. Thanks, labill
Stump Knocker Posted August 1, 2019 #4 Posted August 1, 2019 Are you sure it's not leaking at the hose connection. Did you use new copper crush washers on the banjo bolt connection of the hose when you put it back together?
labill Posted August 1, 2019 Author #6 Posted August 1, 2019 Everything new. I have that diagram so I will take apart again to double check. Thanks
Patch Posted August 2, 2019 #7 Posted August 2, 2019 Its been over honed! 2 choices (yes there are other ways) replace the casting or go to a O-ring supply house and ask for the next size up and again the next size above that one. Check as well that the hone is not too course or too Tall, and that it is round.
labill Posted August 6, 2019 Author #8 Posted August 6, 2019 Went and cleaned it up a little and retightened everything, no little leaks like before but that's just sitting. Been too hot to ride but as soon as I can I will know. Thanks for all the help. labill
