guns_usn_20 Posted July 28, 2019 #1 Posted July 28, 2019 I am going to order my rear brake pads . My question is, is there any advantage to using the sinitered brake pads? Will they damabe the rotor? Thank you in advance Jim Bell
Du-Rron Posted July 28, 2019 #2 Posted July 28, 2019 guns_usn_20 said: I am going to order my rear brake pads . My question is, is there any advantage to using the sinitered brake pads? Will they damabe the rotor? Thank you in advance Jim Bell I am using the EBC FA123V Semi-Sintered brake pad that I believe stops just as well as the factory brake pad and is more forgiving on the rotors than a full-sintered (factory) brake pad. https://www.revzilla.com/motorcycle/ebc-fa123v-semi-sintered-rear-brake-pads
