Jesset Posted July 4, 2019 #1 Posted July 4, 2019 Howdy yall!! new owner here for a week now. i have been on harleys since 2013 and saw this star venture on the floor at a yamaha dealer and i thought i wanted it worse than a cowboy wants a horse. its an 18 model i so far have only one issue with it in 200 miles. when i put it under a load it sounds like the butterfly is clacking on open and close in the efi related to the speed of the engine. i dont think that is what it is but makes me think it is in time with the rpm of the engine. this hammering is loud enough that it is all i concentrate on while riding it. my harley 107 was a whole lot quiter than this thing. doesnt make the sound when off the throttle, just under power. could i have an exhaust leak under there? on another note, the heat is unbearable, can the mufflers be de-catted from the front side of them? i have read every post on this forum and saw nothing that related to my issue.. thanks guys
BlueSky Posted July 4, 2019 #2 Posted July 4, 2019 some of those engines have lifter problems. Get it checked out.
GreenMtnHunter Posted July 5, 2019 #3 Posted July 5, 2019 some of those engines have lifter problems. Get it checked out. My dealer filled it with "low test" I don't really remember the sound, but it improved when I filled it with HiTest. For the heat, be sure your lower vent is open, and I have noticed it's only bad when I am not in my chaps or riding pants. It's also nice when in the mountains in the early morning or at night.
sldunker Posted July 5, 2019 #4 Posted July 5, 2019 Same noise, I always think it is a exhaust leak but not sure. Mine is on the right side as your sitting on bike. I just did an oil test and it came back good so pretty sure it is not cam or lifter noise. For now I really don't worry about it. Heat has not been a problem for me. The hottest the outside temp that I have ridden in has been 89. Might get hotter as temp gets greater. Really like the bike.
GreenMtnHunter Posted July 5, 2019 #5 Posted July 5, 2019 This morning after reading about oil changes and oil choices, I drained the back tank on my SVTC (3 qts) and replaced the stock 20w-50 with 10w40. As the author of the post promised, engine noise was significantly reduced, shifting changed from clunk to click, and the motor was noticeably cooler. I'll be doing the first 600 mile service in a couple days, and I intend to go with a 10w-40 synthetic. Worked for me; your results may vary.
Freebird Posted July 5, 2019 #6 Posted July 5, 2019 I debated which oil to use for a long time. Finally decided on Mobil 1 Racing 4T full synthetic motorcycle oil. Been using it in all my bikes since 1999 and love it. Decided to stick with it. Very pleased so far.
Du-Rron Posted July 5, 2019 #7 Posted July 5, 2019 I debated which oil to use for a long time. Finally decided on Mobil 1 Racing 4T full synthetic motorcycle oil. Been using it in all my bikes since 1999 and love it. Decided to stick with it. Very pleased so far. If you like Mobil 1 products check out their 15W-50 mobil-1-oil-product-specs-guide_2.pdf
Freebird Posted July 5, 2019 #8 Posted July 5, 2019 Their VTwin oil is not JASO rated. That's a no no for me.
Jesset Posted July 6, 2019 Author #9 Posted July 6, 2019 Same noise, I always think it is a exhaust leak but not sure. Mine is on the right side as your sitting on bike. I just did an oil test and it came back good so pretty sure it is not cam or lifter noise. For now I really don't worry about it. Heat has not been a problem for me. The hottest the outside temp that I have ridden in has been 89. Might get hotter as temp gets greater. Really like the bike. almost exactly what i was thinking, exhaust related like a leak.. today i was at the yamahaha dealer and this is a guy working there that has one of these 18's, has 20000 miles on it and he has the same noise since day one so I am gonna call it normal and try to quit worrying about it. now i have to figure out how to make the navigation lady talk to me..
Du-Rron Posted July 6, 2019 #10 Posted July 6, 2019 Their VTwin oil is not JASO rated. That's a no no for me. It's not the 20W-50 you are used to seeing (page 5) it's the 15W-50 (page 3). Check out the chart that I included.
Freebird Posted July 6, 2019 #11 Posted July 6, 2019 The 15w/50 doesn't show to be JASO rated either. Probably not important other than the fact that JASO is specified. I Will continue using what I've using to protect my warranty.
ZOEYDOG Posted July 6, 2019 #12 Posted July 6, 2019 The 15w/50 doesn't show to be JASO rated either. Probably not important other than the fact that JASO is specified. I Will continue using what I've using to protect my warranty. I am using the Redline 20 W50 and have noticed the engine noise quieter.
ZOEYDOG Posted July 6, 2019 #13 Posted July 6, 2019 I tried Redline 20 W50 and found it definitely quieted the motor when hot
Patch Posted July 7, 2019 #14 Posted July 7, 2019 I tried Redline 20 W50 and found it definitely quieted the motor when hot Of course it quiets the engine, that does not make it the correct oil for the engine, nor does it help should a warranty issue arise. Patch
ZOEYDOG Posted July 12, 2019 #15 Posted July 12, 2019 Of course it quiets the engine, that does not make it the correct oil for the engine, nor does it help should a warranty issue arise. Patch Redline meets all the specs
Mike2Fst Posted July 12, 2019 #16 Posted July 12, 2019 Redline meets all the specs I'm also using the Redline 20w50, huge difference, less engine noise, runs cooler (subjective). I'll continue to use the Redline.
GreenMtnHunter Posted July 12, 2019 #17 Posted July 12, 2019 (edited) I'd be interested to hear from others who shell out fot the Royal Purple... I have heard their 10W-40 performs in a similar manner. Edited July 12, 2019 by GreenMtnHunter
Jesset Posted July 13, 2019 Author #19 Posted July 13, 2019 it says remove links from my message then i can post, well i aint got links in my message
Jesset Posted July 13, 2019 Author #20 Posted July 13, 2019 so i will try to answer du-Rron one more time. below this post
Jesset Posted July 13, 2019 Author #21 Posted July 13, 2019 i am having trouble posting Du-Ron asked what happened to me , well as it turns out Jesse T has problems and is so pissed off at Yamaha he is going stir crazy. this brand new bike has an oil leak worse than any Harley i have ever owned and i will be taking it to the dealer probably tomorrow and my riding season will be shot to hell. a few decades ago i saw this girl and her looks were out of this world,, well i took her home and a few years later we got divorced, i lost just about everything. a few weeks ago i saw this Yamaha and her looks were out of this world so I took her home. after riding both of them the ride was great, the engine not so much, and now i don't trust either one of them..very disappointed in Yamaha to say the least. i am to old to miss what riding time i have left. i did solve the heat issue, those 300 dollar lower vents work great my Corbin seat is being shipped today and it will probably never see the bike as i am thinking of cutting my losses and getting another Harley.. 800 miles and back to the dealer, i did the 600 mile oil change, that's when i discovered the leak. o well enough rambling but Jesse T is still here, Mobil one 15-40 wall - mart 33 dollars for 5 qts. advance -auto was going to be 78 dollars
