Chaharly Posted June 12, 2019 #2 Posted June 12, 2019 Wonder how that would work with my teeny tiny narrow venture wheel
luvmy40 Posted June 12, 2019 #3 Posted June 12, 2019 I'm going to drop this here as well. Like I said in another thread, if you are going to trailer any bike at any time you should watch this. No chock necessary. Two straps. No suspension compression and solid as a rock. I've been using this method, but not these straps for years. I've never had any issues with movement at all. BTW, I am a belt and suspenders guy so i do have a chock mounted for hauling bikes in the pick up bed. Chaharly is correct in that they are mostly useless on the Gen 1 venture, chock locks that is. The strapping method works perfectly on them.
Sylvester Posted June 15, 2019 #4 Posted June 15, 2019 I have a Wheeldock, and it is for sale. It has the quick detach mount for a trailer. I have used it for much narrower tires by using plywood shims.
