2007 venture whenever turn signals are on I get all kind of static. Sometimes when driving it will happen also. Suggestions welcomed.
I would start by cleaning the audio plugs in the fairing and put a little dielectric grease on the rubber boots to keep moisture out. Check all your ground connections while you're in there, make sure they're clean an tight. The plugs are on the right side of the radio in the fairing in a large bundle.
  • 2 weeks later...
