loudad Posted June 9, 2019 #1 Posted June 9, 2019 2007 venture whenever turn signals are on I get all kind of static. Sometimes when driving it will happen also. Suggestions welcomed.
RDawson Posted June 9, 2019 #2 Posted June 9, 2019 I would start by cleaning the audio plugs in the fairing and put a little dielectric grease on the rubber boots to keep moisture out. Check all your ground connections while you're in there, make sure they're clean an tight. The plugs are on the right side of the radio in the fairing in a large bundle.
Tennessee Posted June 20, 2019 #3 Posted June 20, 2019 I'd bet money we're talking loose or off ground wire probably in the turn signal circuit, since it only happens with the signals.
